different between y and y1
JPark6
Do i have to use y1 when i sove ode or not?
LucMeekes
(To:JPark6)
Which y1 ?
I don't see an y1.
(To:JPark6)
When you solve via solve block it does not matter which variable you assign the result to.
You may use
a:=odesolve...
y:=odesolve...
or
y.1:=odesolve...
It does not matter.
But why did you encircle the definition of x.f in the photo? This just defines the end value.
