[ e^(-1i*a*x) ]^(1i / a*x) - e = 0 , substitute,a=2, solve,x . How many solutions ?
lvl107
20-Turquoise
Thanks in advance.
LucMeekes
(To:lvl107)
The answer should be:infinite
(e^B)^C=e^(B*C)
in your case B=-iax and C=i/(ax), so B*C=1
That simplifies your equation to e-e=0
any value of x will do, as long as it's unqual to 0.
(To:LucMeekes)
(e^B)^C=e^(B*C)
As we are obviously dealing with complex numbers, thats only true if C is an integer! Otherwise any complex number with magnitude e^(B*C) and argument any integer multiple of C*2*pi is result. If C is irrational thats even an infinte number of results.
But as the question is about solving that equation, your solution is valid nonetheless: if a is unequal to zero, x can be any value different from zero, otherwise x is undefined.
