This sheet represent calculation of hydrogen flow from through the porous membrane as a
function of time. The flow is experimentaly measured ("measuredFlow") and calculated from current (CurrentData), in order to compare yield. Notes reperesent temperature at certain time.
I want to correlate flow at the certain temperature, at a certain time.
This is performed by "CoolingIndex". The data in CoolingIndex table are acctually indexes
of the "absFlow", which is the flow at the certain time, at a certain temperature. And I want to extract only absFlow data with the index k.
The values in the CoolingIndex table are as they should be, when i perform this in Excell (manually). But somehow, the values of k are not the same as values in the CoolingIndex table. Where I am making a mistake? How can I obtain k, the same as the values in the CoolingIndex table.
Thanks!
I'm a little confused. Is the absFlow[k values correct?
Mike
Success, I think.
Have a look at the attached.
Mike
The problem is solved. Thank you very much! If it is not a problem, can u explain me the meaning of the math used in inserted image and how actually works because I want to know for the future....
Explanation in worksheet.
Hopefully it helps.
Mike
