how to change label font size
MySchizoBuddy
I want to change the font size of axis labels. But when i select the label the text formatting box is greyed out.
Follow these instructions:-
  • Click format
  • Equation
  • Choose 'Math text font' under style name
  • Then select Modify
You can change the label properties there.
Mike
10 REPLIES 10
  • Click format
  • Equation
Mike
That won't change the labels, only the variables in the axis placeholders. There is no way to change the font of the labels.
mzeftel
(To:RichardJ)
The steps Mike wrote also apply to the axis labels. I just tried it.
Mona
RichardJ
(To:mzeftel)
I just tried it too, and it didn't work for me. If I plot x against sin(x) then I can chnage the fonts for x and sin(x), but if I add axis labels and a title, say "x-axis", "y-axis", "My Graph", I see no way to change the font of those. Am I missing something?
wayne
(To:RichardJ)
If I do as mike says, whether or not I slect a graph, I and change the Math Text Font, from the main menu, I change the fonts on all graphs. I don't think you can have different fonts on different graphs. From Help, the Math Text Font style is used for graph labels.
For the arguents, if you slect a graph you can change the arguments (sin(x), x) individully by changing to a user font (user1, user2, etc.), and that will change that argument only, note that you must change sin() and x independently. You are free to modify the user fonts.
RichardJ
(To:wayne)
Ah yes. Thanks. I was modifying the wrong font. That's what you get for not reading the instructions properly!
I'm sure you came across this the other week.
I remember you saying "Nice trick, didn't know you could do that"......
Mike
Surely you don't expect me to remember something from over a week ago!
http://communities.ptc.com/servlet/JiveServlet/showImage/38-1286-6353/Duh.gif
Sorry, it is nearly the weekend.
Mike
Are you sure???
Mike
