I am trying to use custom units in MCP v11. I have an included worksheet that includes a lot of domain-specific units and functions. This has been carried over from MCv15 and previous. I am now noticing that some of these definitions aren't working - I have distilled everything down to one simple example of success and failure, with no apparent reason why. See attached.
I also tried to do my due diligence and see if anyone was reporting anything similar. Why there are lots of questions related to use of units, I didn't see a similar issue being reported.
I had no problems to change the label of "rrpm" and "krrpm"from "Variable" to "Unit" via the menu.
But I remember that from time to time in the past I had a similar problem as the one you describe - changing the label via the menu did not work as the label would immediately snap back to "Variable" as soon as the focus was out of the region.
I don't know what caused that misbehavior.
But changing the label using the keyboard shortcuts always worked OK.
You can use Ctrl+Q to cycle through the seven label-types or you can use Ctrl+U to toggle between "Unit" and "Variable".
According Prime processing disabled regions: No, I don't think that disabled regions are processed to any degree. When you disable a region you still see the state the region was before disabling it.
So if you have a second global definition of the same variable or unit (which Prime no longer allows, unlike real Mathcad) is gets red bordered and when you disable the region the red border persists. I would call it a buggy behaviour or at least something undesirable.
Its similar to evaluating a variable
and after disabling the evaluating region it would still show the former result
I think it would make more sense if all calculation results and error indicators would be deleted when a region is disabled.
On the other hand 'freezing' a result to compare it with a calculation done with changed input values might make sense in some cases, but there sure are other options as to achieve a similar effect.
According persistent error indicator I noticed an even worse effect in 2D plots. A red error border around a plot region would not go away even though the problem causing it was already fixed. A recalc did not solve the problem, saving, closing the sheet and reloading it did. A more convenient solution was to cut and then paste the plot region.
Thanks Werner - I tried the Ctrl-Q/U trick and that worked - glad to know (hope I can remember) - I assume this is documented in help somewhere? As for the disabled regions thing - I agree, it seems that the red box is static once the definition is disabled. I also discovered a difference between the local and global definitions -see updated attachment.
updated file.
The weird thing is that when I reopened this doc I still saw the stuck label (stuck as variable) and several of you had no problem with this document. So it isn't the file itself??? Does that point to some system issue?
@krs wrote:
updated file.
Not exactly sure what you mean!?
When I opened the first file you posted I saw that "rrpm" was labeled as "Variable" and so using it as unit when evaluating the 10 Hz failed.
I understood that you were not able to permanently set the label when you define the unit and I remembered that I has the same problem sometimes in the past. I can't say what causes that erroneous effect and why it was going away.
But the file you posted now seems to be perfectly OK.
The error seen in the left picture you embedded in the file stems from the fact that of course you can't use a variable (or unit) defined the "normal" way ( with ":=" ) in a global definition. This is expected behaviour (and also was so in real MC15).
According the documentation of the keyboard shortcuts Ctrl+Q and Ctrl+U. They might(!?) be documented somewhere in the help but when you are looking for that kind of information, Prime's help sure is ... demanding, to say the least.
I'm not sure how and where I discovered these keyboard shortcuts.
Maybe it was just through trial and error—the same way I found the window that lets you change a few colors and other settings.
Namely, with Shift+Ctrl+Alt+Q, which is probably not documented anywhere—use at your own risk 🙂
BTW, even though it possibly has nothing to do with your problem of not being able to set the label vie the menu, I agree with Stuart that its a good idea to avoid global definitions whenever possible. This was a good advice already for old Mathcad and still applies to Prime.
Hi Werner, could you clarify please? something may have clicked in my head
Do you mean that anything with a global-equal assignment must be intrinsically defined? i.e. no dependencies on other variables?
When precessing the worksheet in a first pass only the global definitions are parsed. So when a global definition uses a 'normal' one, it has not yet been processed and is therefore unknown.
A globally defined variable (or better: constant, as it cannot be altered in Prime other than via the API) can depend on others, but these must be defines globally as well (and above it). In fact you did exactly that when you (globally) defined the unit krrpm based on the (globally) defined unit rrpm.
On the other hand a normally assigned variable can use any globally defined one, no matter if its defined above or below it.
Of course, given Mathcad's evaluation order, there is occasionally/sometimes/frequently a need to define a function or variable further down a worksheet where it makes more logical sense, but you want to use it further up the worksheet.
I once proposed a few potential mechanisms for avoiding this need.
(a) As in some programming languages, add a 'forward' directive that tells Mathcad to look further ahead for the actual definition.
(b) Making use of the warning system, and have an option to turn off errors for undefined variables. Instead, have Mathcad automatically look ahead for an undefined variable and flag up a warning instead.
(c) Add a manual means of unidirectionally linking two regions to bypass the implied interpretation order.
(a) would probably have best as it follow Mathcad の禅 (no zen) 指導原則 (shidō gensoku) 6 -- Explicit is better than implicit.
OTOH, maybe I should remember the implicit Zen 15a -- And never is sometimes better than ever.
Stuart
by "this doc" I meant the first/original worksheet that both you and Stuart apparently had no issues with. Maybe I misunderstood.
The new Maths Label sticks for me.
However, I notice that you're using Global Definitions. The behaviour of these is markedly different from M15. You can only define a name *once* using a global define. Unless you have a pressing and unique need to use a global definition, I'd suggest you use the colon-equals definition.
Stuart
Hi Stuart - I had tried both definitions before and had the same problem (couldn't change a label from 'variable' to 'unit'). However, I did notice something else between the two definitions. See my response to Werner
Hello @krs,
It looks like you have some responses from our community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Providing an update as I continue to explore this. Thanks for all the input and wisdom. I will change all of my definitions in my included 'units' file to ":=", (local definitions). I don't imagine search and replace will work for that? Along those lines, any idea how to do search/replace operations on subscripted variables? Now that the subscript mechanism is not a character (ctrl+'-' vs '.'), you can't search for full subscripted variables.
Here is my new discovery - "including" a file appears to make the units definitions appear as 'variables' to the worksheet that envelops the included file. Here are my two test cases - maybe I'm drawing the wrong conclusion?
