The attached sheet poses a question about matrix math; I'm a bit confused apparently about multplying vectors and matrices. The symbolic math seems to indicate that I should get the same answer with either method, but the numeric application shows clear differences larger than rounding errors should allow.
What am I missing??
You simply forgot to transpose MAT in the first numerical case!
Alan
Duh!
Thanks for putting up with silly mistakes!![]()
We all make them!
Alan
