matrix indexing using parentheses
StuartBruff
23-Emerald V
Let me tell you a story.  Once upon a time, perhaps even 10 minutes ago, when writing a new function (Bidiagonal) and testing it with strings, I replaced a direct function call argument with a predefined vector but forgot to remove the original function's argument.  After a few seconds of gazing at the (correct) output from Bidiagonal, I realised that the notation V(3) for vector V should have raised an error, but it didn't.
After a bit of playing with a new, blank worksheet, I confirmed that to get an array's elements, one can use the standard subscripted index notation Mi,j or the standard programming language parenthesis notation M(i,j). And Little Red Riding Hood and Peter campaigned for a better public understanding of wolves, their role in ecology, and their treatment.
I have a vague, dusty, indistinct memory of coming across this notation before, perhaps even on this forum, but I'm not sure - it might be a case of déjà vu.
Stuart
LucMeekes
(To:StuartBruff)
It is one of the two supported means to index an Array in Prime.
And it is confusing.
And it takes up more space.
And you cannot use this notation to access elements of nested arrays.
So I never use it
16 REPLIES 16
LucMeekes
(To:StuartBruff)
So I never use it
Yes, I agree, Luc.
I had a quick play with nested arrays but couldn't find a way of indexing them by extension of this notation.  I was rather hoping I'd be able to do something useful, such as P(1,1,1,1) to get at an element - that would make using nested arrays more straightforward and be the basis for a proper multidimensional array (MDA) system ... I may have mentioned/requested MDAs on the odd occasion.
Do you know if this notation is documented as well as supported?
Stuart
LucMeekes
(To:StuartBruff)
AFAIK it's supported, and I hope it's documented. It's been in since Prime 1.
(To:StuartBruff)
Here is another difference - guess you did not try to change the value of ORIGIN.
The functional notation is ignoring the setting of ORIGIN - similar to the third argument (generating function) in the "matrix" function.
I can confirm that this 'feature' has existed since Prime's inception and I've railed against it a time or two here for a couple of reasons.
However, I haven't come across any official documentation on it, so I couldn't say that it's officially supported by PTC. It's also possible that it just happened unintentionally.
In my opinion, it would have made more sense to eliminate this 'feature'. Just as the undocumented ability to quickly and easily convert ranges to vectors was eliminated in Prime 10, but unfortunately without providing a (more logical and intuitive) alternative.
StuartBruff
23-Emerald V
(To:Werner_E)
Your Werner railings.jpegs are possibly what I might have seen, but forgotten about.  Apologies if so; my memory is as bad now as it was then.   Although I have a very vague recollection of seeing this when I was modifying my multidimensional array worksheets to work with Prime Express.
Whilst PTC are fixing this indexing feature, it would be nice if they'd give some consideration to fixing two particular bug bears I have with the normal indexing notation.
  • Cannot use deep nested array indexing on left hand side of a definition, although it works in an assignment.
  • Programmatically and visually, nested indexing, whilst unambiguous, isn't flexible enough to cater for irregularly shaped nested arrays.  The ability to use a single level indexing would make it easier to see the indices and to handle deep arrays.
ISTR that you couldn't use nested indexing in an assignment, either.  Did M15 or early versions of Prime allow it?
Stuart
(To:StuartBruff)
Here is what you did converted to Mathcad 15.
StuartBruff
23-Emerald V
(To:Werner_E)
Interesting.
What do you get if you use P0,0,1,1,1 inside your Q program?  I presume it also ignores the extra indices, but given that local assignment works while definition doesn't, that presumption is just guesswork.
Prime telling you it won't have anything to do with more than two indices is better than quietly ignoring them.
Stuart
(To:StuartBruff)
@StuartBruff wrote:
Interesting.
Correct. MC15 ignores everything after the first two indices, not even checking if the variable used is defined or would be valid integer.
Agreed on, yes.
And sometimes I even wished that Mathcad/Prime would throw an error instead of silently applying implicit vectorization.
This is especially true if I modify a function which formerly did not use any calculations valid for vectors in a way that the results now are different whether vectorization is explicitly applied or not and me not realizing that firsthand. That way I learned that its better to apply explicit vectorization every time you want it to be done and don't rely on implicit vectorization. That's also the reason I prefer to put the vectorization when I call a function and not in the function definition itself - just to remind myself whats going on and of course at the cost of uglier display and unnecessary increase in global warming.
StuartBruff
23-Emerald V
(To:Werner_E)
@Werner_E wrote:
@StuartBruff wrote:
Interesting.
A good guess on my part, then.  Perhaps I should get a crystal ball and enter the world of sorcery and prognostication. Who knows, maybe become the new urYod. 😃.
I'm having difficulty focussing on reality at the moment as the wind has been gusting quite nicely ...  It blew open a window that was latched very slightly open and the house has been shaking and making noises seldom heard outside of a large galleon about to break up in a rough sea.  That means I'm paying more attention to the weather than the seven Mathcad worksheets I'm currently working on.
I'm afraid I find implicit vectorization to be more helpful.  Explicit vectorization requires a bit of thought as there may well be array arguments that shouldn't be vectorized when calling them or are of different sizes to the main object of the vectorization. This requires me to think about and implement the same process each time I use explicit vectorization - but thinking makes my brain hurt, and thinking just the once is bad enough.
For example, I often use implicit vectorization to allow a notionally non-array argument to be overloaded with an array as well.   By transferring the vectorization to a function, I have more and consistent control over what gets vectorized and how.
Great care with vectorization, one must take.  Things nicely to do, always possible it is not.  Which is why a map function,  sometimes I use. Or even (gasp!) to ugly explicit iteration, resort I do.
Greenpeace has acquired your name, young Master Werner.  Don't ask me how or who told them ... hordes of indefatigable volunteers are furiously painting banners as I type.  😈
Stuart
Of course, sometimes one must be careful what one vectorizes for ...
Stuart
(To:StuartBruff)
@StuartBruff wrote:
Of course, sometimes one must be careful ...
Don't you always have to be?
And yes, of course there are sometimes good reasons to pack the vectorization in the function definition, especially if it is a function that is designed to be fed with vector arguments.
StuartBruff
23-Emerald V
(To:Werner_E)
Yes, but I meant "CAREFUL" instead of merely "careful".  Some values of careful don't require much in the way of thinking; they just require observation and a vague sense of situational awareness.  Other values of careful require an entire squad of genius-level Care Bears totally focussed on every little detail and possessed of a strong sense of paranoia.
Indeed.  I generally take the approach, "What if somebody needed to vectorize the arguments? How could I best implement it?".  I often end up vectorizing even simple functions because I had a need to vectorize the arguments or even to be consistent with how Mathcad implements many functions.
Stuart
Well, when I say Bears, clearly I mean Racoons, such as those with Bright Hearts.  Although, I suppose Grumpy Bear and Smart Heart Bear might be good team players.  I'm a bit suspicious of a few of the Bears, though.  I suspect they'll give you an answer that you'll endorse if the correct answer upsets you.  They'd definitely support the "p = 3" Party members rather than see them upset by all those distasteful digits appearing after the decimal point.
LucMeekes
(To:Werner_E)
Mathcad 11:
Errors:
- The expression to the left cannot be defined.
- This array has too many subscripts.
Incidentally, it is possible in Prime to (re-)assign an element of a nested array:
You can even create new elements:
Mind that, like the 'function' notation of indexing, the update1 and update2 functions use ORIGIN=0 irrespective of the value of ORIGIN.
(To:LucMeekes)
Ah yes, thank you, I had completely forgotten about these undocumented functions. So now it's up to us to decide which way of writing seems more appealing and intuitive and whether we are prepared to use undocumented functions ...
It seems only to be mandatory that in he program the global variable N is used on the right hand side of any assignment before we can use it in the desired way.
I dimly remember that we had something similar here some time ago, but I have no idea what it was all about. 😞
Here is a tense one-liner
and, no, I won't call it appealing and/or intuitive 😉
StuartBruff
23-Emerald V
(To:Werner_E)
That's so ... specific.  😱  Instinct forced me to generalize it as a function.  But both you and Greenpeace will be delighted to see I didn't implicitly vectorize the function.  😊
Life would be so much easier with a decent Sequence data type.
Stuart
I'd forgotten about the update functions, Luc. Within Mathcad Prime Express, I tend to avoid them, preferring a purely functional approach rather than indulging in nasty state-changing behaviour.  fold I use heavily.
However, looking at one of your earlier messages in this thread, I hope PTC regard them as Features rather than Bugs or Unintentional Behaviour, given their Prime longevity.  Consequently, I also hope to see the documentation scribes scribing away and adding them to Mathcad Prime Help.
Stuart
