I'm trying to find the effective stress, I wrote a program in mathcad however the result was zero always
I think the error occurs because of the depth . Since I need to use the previous depth of each stress and not the depth in the same point.
Can anyone please help me?
Also I need to find the midden value but not sure how to find that
in excel
in mathcad
A for-loop needs at least a start and a stop value (like a range).
Are you looking for this
or should it rather be this
And then
No need for defining any range variables like i.n or j.n
Prime10 sheet attached
Please upload your Mathcad Prime worksheet here.
You probably want:
rather than
(I can't test it as I only have an Express version).
thank u
And then
Thank you
thanks
