odd even numbers
SFares
odd even numbers
my question is inside the mathcad sheet. it is about when the value is odd to return a certain value, and when it is even to return a different value. Thanks!
(To:SFares)
Find attached one way to do it.
11 REPLIES 11
(To:SFares)
You are making a mistake in thinking that in the odd case you will just get 2,6,,10, etc. Thats simply not true - Ceil will yield any multiples of 2 and because N=4 and 4 IS a multiple of 2 you get N=4.
Fred_Kohlhepp
23-Emerald I
(To:SFares)
Okay, If Npanels = 4 and TC = 18, you want Nf = 6.
Give us a few other examples:
Npanels = 4, TC = 17, Nf = ??
Npanels = 4, TC = 10, Nf = ??
Npanels = 4, TC = 7, Nf = ??
Interesting part would be different values of Npanels, as TC=17 and TC=7 sure should yield the same result (given the same Np).
Maybe something like this
SFares
(To:Fred_Kohlhepp)
TC will always be an even number, but the divsion by 2 can be either odd or even. i have added more clarification in the attached sheet. Please let me know if you need more explanation. Thanks to you all!
(To:SFares)
SFares
(To:Werner_E)
Thank you Werner so much!
(To:SFares)
Here are three more equivalent functions, all based on the same principle
SFares
(To:Werner_E)
Thanks a lot Werner !
Fred_Kohlhepp
23-Emerald I
(To:SFares)
okay, try this:
Nice appraoch, but you you have to replace TC_Panels by the argument tc in the routine.
You may also make it more compact:
SFares
(To:Fred_Kohlhepp)
Thank you Fred! i like your approach too.
