problem with tables
jsznajder
problem with tables
Hello!
I would like to ask you how to cope with a table that needs description, by that i mean f.ex. row's name. Below I attached a screenshot from Excel. Is it possible to do sth like that in MathCad? Moreover I would like to oparate later on rows, f.ex. new row which is the result of substraction of 2 predecessors.It should be presented in a clear form (technical report) I am beginner with that programme and have no idea how to do it. And is it possible to somehow fill in table descrption ranges of load (like in the first row below)? Thank you all for help and advices.
(To:jsznajder)
Cells of matrices can be text strings, too (in Mathcad text is to be enclose in "-signs)
You can then use the result format menu to present the matrix as table.
Be be aware it will never be that pretty looking as you can make an Excel table look.
9 REPLIES 9
(To:jsznajder)
My whole formatting tab is frozen when I mark my matrix, so I have no possibility to edit its form. It works everywhere in the worksheet but not in matrices =/ Thank You for reply, that looks decently
(To:jsznajder)
I just remember that you use Prime2, not Mathcad15. In Prime you don't have different views (matrix/table) for matrices.
On the other side new in Prime is the option to "Insert table". This is a table with header lines for names and units. Unfortunately this sort of table is only meant for manual input and cannot be created by a program.
You format matrices via "Matrices/Tables" tab
Sorry, it is not a table - it is a set of separate vectors and scalars. Vectors must have elements with same dimensions.
Sorry, PTC calls this construction a "table" in Prime. This in contrary to Mathcad 15 and below, where a "table" was meant being a specific view of a matrix.
Anyway, you are right thats best for us to look at the new tables as a set of vectors.
A set of vectors and scalars.
See one picture from the article "Scalars and Vectors in computing" http://twt.mpei.ac.ru/ochkov/Mathcad-15/ScalarVector.pdf
The main idea of the article is - Mathcad (and others Math packages) has two type of vectors - "correct" (physical) vector (see the picture: Сила - force, Масса - mass, Ускорение - acceleration) and and "not correct" vector (a set of scalars). Mass is a scalar, Force and Acceleration are vectors.
I don't use Prime2 myself and am just playing around with it from time to time (mainly when somebody here has a question). So I was not aware the the vectors in Primes table are allowed to have different lenght - nice.
I see that mass is a scalar, not a 1x1 matrix as I would have expected - but it makes sense.
It is a "correct" table in Mathcad Prime - http://communities.ptc.com/docs/DOC-2151
The tables in Prime are a big improvement on M15, but this issue needs to be addressed. M' should allow variables to be passed and displayed in tables.
Mike
