programming question.
elund
8-Gravel
I want to have several parameters take on different values depening on material selection. I have been unable to use text in if statements so far. The best would be if the user could select the materials from a set of selections. So far I have done it bu using an embedded excel sheet and doing the input in there, but I am not happy about it. Do anyone have an elegant solution for this?
For example:
Material="S355"
a=2
b=3
c=4
Material="316L"
a=0.5
b=1
c=5
etc...
any help is much appreciated.
AlvaroDíaz
(To:elund)
Hi Espen.
Attached one option, there are a lot of others.
Best regards.
7 REPLIES 7
AlvaroDíaz
(To:elund)
Hi Espen.
Best regards.
thank you
ViktorKorobov
(To:elund)
Alternative solution:
Insert->Control->WebControl->List box/combo box
Viktor
Viktor
I am actually using PTC Mathcad Prime 3.1. Such a solution as you presented is what I prefer, but I am not sure it is possible in prime. Or at least, I have not found a way to make a list where the user can select the desired input.
nas0k
(To:elund)
Someone posted this example recently, which may be useful.
Norm
elund
8-Gravel
(To:nas0k)
This is a good solution, thanks!
VladimirN
(To:elund)
In Prime 3.1 version there are no active control components.
