simple help with mathcad file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I am having difficulty with opening the attached file with my version of mathcad could some please open the attached file and print contents as pdf? Thanks
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
This can open with Mathcad 15.
What version of Mathcad do you have?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
unfortunately 7 😞 advocating for new version but don't have funding yet. Could you post a pdf of the file for me?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
thanks fred
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
It is not .pdf, can it serve the same?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Here's the pdf with all collapsed areas opened und some inserted page breaks for better readbility.
I also add the file in Mathcad 11 format - maybe someone with Mathcad 11 can convert it to MC 7 format.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Attached. saved as Mathcad 7.
It gets big, because when saving as, everything that Mathcad 11 'knows/thinks' is not supported by mathcad 7 is (also) saved as a picture.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Obviously the collapsed regions are not supported.
Would they save as needed if you open them first?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I didn't look inside.
Here's another attempt with all (were there three?) areas opened. File is even bigger.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I think you got all areas.
Not sure why the file is larger. It contains some Pics and Excel tables. Maybe they are stored less efficient in older versions?
There is also a compatibity issue jgrady will have to deal with because the sheet takes "advantage" of the different way, MC12 dealt with local assignments (we have a compatibility switch MC11 vs MC12 in newer versions of Mathcad for that reason).
@jgrady
You will have to manually add a return value to a lot of the calculations. One example:
has to be changed to
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
This document was created in Mathcad 12 version. So you can open it with Mathcad 15 30-day trial version: Thank You for Your Interest in PTC Mathcad 15 | PTC
