solution to ODE system
ptc-6141584
Hello, everyone.
I want to solve a somehow complicated ODE system of 5 equations. But the Software seems have problem to solve it.
If I change the y5 in the 4th line of my DD matrix, it can be solved. But the results are definitely what I expected.
Please check the attachment for the situation.
So the questions are:
1. Why the MathCAD have problem with solving my origenal matrix?
2. what change I need to make to get the results?
(To:ptc-6141584)
Vector elements are numbered beginning with 0 by default (is controlled by system variable ORIGIN) and so there is no element nr 5 in your vector y (which consists of just 5 elements 0,1,..4).
You have used index 0, 1, 3, 4 and 5. This would assumer either a vector with 6 elements or maybe, as you haven't used index 2, you are supposed to decreement the last 3 indices by 1.
(To:ptc-6141584)
thanks, this is like the first MathCAdD I write after switch from MatLab. What a natural mistak. lol!
y has 5 components numbered 0 through 4. There is no component number 5. In DD you have not used y2; I guess it should be there somewhere and you should only be referencing numbers 0 to 4 (remember that, by default, Mathcad starts numbering vectors from zero).
Alan
Edit: Werner just beat me to it!
Thanks very much!
