solve cot(x)+e^(x-pi)-1/((e^(pi))*((e^(x*i))^i))=0 for 6<x<13 ?
lvl107
20-Turquoise
I.PNGsee : https://www.wolframalpha.com/input/?i=solve+cot(x)%2Be%5E(x-pi)-1%2F((e%5E(pi))*((e%5E(x*i))%5Ei))%3D0+for+6%3Cx%3C13
If someone could explain above the above, please help.
Best Regards.
Loi.
(To:lvl107)
Guess you found out that uncle Wolfram isn't perfect, either.
You get different solutions depending on if you chose 6<x<10 or 6<x<13 and you get the same solution twice - too bad!
For another funny effect you may click on "More digits". All in a sudden Wolfram offers two more solutions and both are not within the constraints.
Looks like the world isn't perfect and math progs aren't, too 😞
7 REPLIES 7
LucMeekes
(To:lvl107)
This should do it, together with all help you've received over the past days explaining the ins and outs of dealing with exp(i) in various forms:
lvl107
20-Turquoise
(To:LucMeekes)
Luc, I guess there is a misunderstanding my question :
IIa.PNGI need a explanation about how to get the second solution, x = 6.237916547633475
see : https://www.wolframalpha.com/input/?i=solve+cot(x)%2Be%5E(x-pi)-1%2F((e%5E(pi))*((e%5E(x*i))%5Ei))%3D0+for+6%3Cx%3C10
Best Regards.
lvl107
20-Turquoise
(To:lvl107)
I need help explanation about the Missing solution - How to get the second solution x = 6.237916547633475 from that formula, from that hint.
Best Regards.
lvl107
20-Turquoise
(To:LucMeekes)
I have just done for solving one of other missing solution "by hand" with root function and guess value x = 12.566289908047107. ( that is the reason for explanation how to get other missing soution from that formula, from that hint.
Best Regards.
lvl107
20-Turquoise
(To:lvl107)
Or : I need help explanation about the Missing solutions - How to get the other solutions from 6<x<13,  from that formula, from that hint.
(To:lvl107)
lvl107
20-Turquoise
(To:Werner_E)
Yes. I guess so, Werner.Smiley HappySmiley HappySmiley Happy  and anyway I guess we would have to solve it "by hand" with root function and guess values. And another example :
https://www.wolframalpha.com/input/?i=solve+tan(x)%2Be%5E(x-(pi%2F2))-1%2F((e%5E(pi%2F2))*((e%5E(x*i))%5Ei))%3D0
b1.PNGb2.PNGRegards.
