I am needing to sort the values from the columns in a matrix. I know you can use the csort function but that only sort one column at a time and leave the other columns unsorted. I need to sort all the columns at once from low to high. Any ideas.
Thanks.
Look a picture.
That should work. Thanks for the detail. You did anser my question.
