Dear all,
I have been trying to do a cubic spline for on a mechanical spectral response. Unfortunately the spline does not work, can anyone explain to me why is this happening?
I have used it in the past many times, without any problems(different data).
Is there a easy solution for this ?
Cheers to all!
João
Here is a quick solution.
A routine which sorts and removes lines in a matrix when the elements in the first column are duplicates.
Only the first line will survive. A more sophisticated approach maybe would average the values in the other columns rather than throwing away all but the first.
The problem is, that you have a lot of duplicate values in your abscissa vector XE1 and thats what Mathcad's spline interpolation chokes at.
More accuracy is needed in the source data?
Thank you all!
Werner! Thats amazing. Thanks!
