Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Mostly you can't. In MC14 you can use the combining ^ character (Unicode). It works with some fonts, but not with all. __________________ � � � � Tom Gutman
On 10/15/2009 1:28:51 PM, rwpatterson357 wrote: >How can i add a "hat" symbol >above a variable? > These are the ones I most often use. To enter, toggle NumLk, then hold down the Alt key and use the numeric keypad to enter the number.
Example of using the combining ^ character. You might be able to find a font you find acceptable that renders this correctly. __________________ � � � � Tom Gutman
