1.First question? How i can change axis unit? i want degree? i was searching tip in google and only find answer "To set the units in a plot, divide the plotted parameter by the desired units" i don't know how i can do it?
2.Second. I need answer of my graph, i need a (alfa) value where the functions are collising?
1 use alpha/deg on the x axes
2 use Trace
2 use Trace
thanks
thanks
You welcome!
One Mathcad-video from LT:
i have understood trace, but how it convert apha/deg i don't know, i write near alpha on axis "/deg" but it don't show degree. Can you help, also i would like that find command show not radian but degree.
thanks , i understand now, there was problem with degree range. Thanks
We can use this tools for the guess value setting:
And second.
For one equation (not for a system) better use not Gthe iven-Find but the root function!
