unable to yield arrays with integrand of complex number and input arrays
ashankar
The mathcad is unable to solve definite integral to yield array output. The input is also in array form. Even if I put limits in the closed form of integral it yields only a single value instead of array. Please solve this problem. The integral and other steps with problems are highlighted.
6 REPLIES 6
Hi. Hope this helps. Best regards. Alvaro.
Sorry, for the delayed response. That is the solution which was required.
thank you
Can you please find sometime to answer my other questions? thank you
try this
thank you
