whats the difference
QUTADAh
6-Contributor
Hi guys as you see I am using this matrix and want to find eigenvalues and vector but dont understand the difference between two numeric and symbolic solutions, why are they different?
LucMeekes
(To:QUTADAh)
You should realize that Mathcad contains a numeric processor an a symbolic processor. They approach your mathematical problem form a different standpoint, and therefore can produce different answers to the same problem.
6 REPLIES 6
(To:QUTADAh)
On contrary to Eigenvalues, Eigenvectors are not unique. Every multiple of an Eigenvector is an Eigenvector, too.
So you are free to use (1;1) as eigenvector or (0.75; 0.75).
Mathcads numerics uses eigenvectors with length 1 while the symbolics doesn't normalizes that way.
For future questions: Instead or additionally to pics please always attach your worksheet.
QUTADAh
6-Contributor
(To:Werner_E)
Worksheet is usually long thats why i attach a pic instead..
LucMeekes
(To:QUTADAh)
QUTADAh
6-Contributor
(To:LucMeekes)
and how do I know which answer I want? thanks!
(To:QUTADAh)
How should we know which answer you need?
If you don't know why you calculate eigenvectors of a matrix and what you should do with them, you probably don't need to calculate them at all 😉
The worksheet with the eigenvectors sure is not too large and if a worksheet you experience a problem with is too large or contains confident data, you should try to narrow down the problem and create a smaller example sheet which shows the problem/error, too. After all, its hard to debug just a picture and we often need a live worksheet to play with, to find the reason for an error or a suitable workaround.
QUTADAh
6-Contributor
(To:Werner_E)
Actually I just made this code to ask the question with Symbolic and numeric solutions, I am not directly interested in the eigenvector itself, but this cleared it up now! For the future worksheets I will just narrow down the problem and post the worksheet to make it easier for you guys to play around with.
Thanks alot !
