Bind request failed: [message: BindRequestMessage
rodolfocorral
9-Granite
I am getting these errors in the Thingworx logs every second for one of my OPC Servers.
Bind request failed: [message: BindRequestMessage [requestId: 249229, method: BINDREQUEST, names: [FINDBZOPC1-GW]], error:{}]
Any idea about what could be the cause?
Let me know,
2 REPLIES 2
Hi @rodolfocorral,
It seems that your ThingWorx not able to connect to your OPC server using FINDBZOPC1-GW.
Can you check if the name of gateway thing is exact same at both end. Also validate the template of FINDBZOPC1-GW is of Gateway type (like IndustrialGateway for KepServerEx)
If the error still persists please share the application logs and OPC server logs for further investigation.
Himanshu
Hi @rodolfocorral ,
Can you please update whether the provided recommendation working for you.
Or if you have found a solution to your problem, please feel free to post it here for the benefit of others on the community.
Once you have done so, please mark it as the Accepted Solution.
Himanshu
