Unable to view control Advisor in my composer.
AS_1307
Hello Everyone,
I'm using twx composer version 9.3, and I've imported twx Manufacturing common as for twx manufacturing app, I've even exported the thingworx asset monitoring and thingworx utilities, in my local server. Now the problem is I'm not able to see control advisor.
Please let me if I've exported the correct manufacturing extensions or not, if yes, then why can't i able to see it in my composer.
Thanks in advance!
AS
I installed the MFG Apps but when I open the applicattion on the browser I only
3 REPLIES 3
slangley
23-Emerald II
(To:AS_1307)
Hi @AS_1307.
This could be a licensing issue.
In Composer, navigate to Monitoring > Subsystems > LicensingSubsystemSettings, and provide a screenshot of all the features you see there.  Be sure to capture all columns and rows in the screenshot.
--Sharon
AS_1307
(To:slangley)
Hi Sharon,
PFA,
AS
slangley
23-Emerald II
(To:AS_1307)
Hi @AS_1307.
Your license looks fine.
After re-reading your original post, it sounds like you may not have installed all the needed components.  When you installed Mfg Apps, what procedure did you use?  You need to follow these instructions.
--Sharon
