Mini Toolbar - Annotation not working
ThomasKirkman
There are times, when in Annotation, the mini toolbar will appear, but pressing the buttons fails.  Normally, when hovering over a button, text will pop up giving a description of what the button does.  That does not even happen.  Does anybody else have this issue?
I wonder if I have something buried in my customization's that prevent it from working all of the time.
Tom
Creo Element\Direct Modeling 20.6.0.0.0
I have the same problem and didn't find any solution.
Sometimes ESC helps, often not.
It appears over several versions from 19 to 20.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
Hello colleagues
the command for the mini toolbar is
oli:sd-define-application-cmt-contents
Have you already searched your customizations and the lisps you load for a wrong occurrence of the command?
Search e.g. for the textstring
"application-cmt"
With Notepad ++ it is very easy.
Best regards
Friedhelm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
