convert to .dwg scale 1:1
ssusana
6-Contributor
I need convert .mi file to .dwg scale 1:1, because in annotation the views are scaled and I need convert the drawing in dwg real dimension.
Can someone help me?
Thank you.
Stefano
ssusana
6-Contributor
(To:ssusana)
can someone help me?
thank you.
Stefano S.
According to PTC, convert the views to 1:1 scale before exporting.
https://www.ptc.com/en/support/article?n=CS54595&language=en&posno=1&q=dwg%20export%20scale&ProductFamily=CoCreate%20%26%20Creo%20Elements%2FDirect&source=search
I hope this helps.
Tom
Creo Element\Direct Modeling 20.6.0.0.0
dhull
(To:ThomasKirkman)
Change it manually view the view properties dialog...
Automating this with the integration kit is also doable. Either way gets complicated if you use a border.
ssusana
6-Contributor
(To:dhull)
I try, thank you.
ssusana
6-Contributor
(To:ssusana)
I write a lisp to convert the sheet in dwg scale 1:1.
I set ConvertMIDimensionsToGeometry  to ON because dimension works wrong during the traslation.
;converte i disegni in dwg con viste scala 1:1, utile per esportazioni cad-cam, taglio laser, etc
;necessita d'impostare il parametro "ConvertMIDimensionsToGeometry ON" del file DXFDWG.CON e per questo ne ho creato uno dedicato.
(sd-defdialog 'SntDwg-1.1
:module       "ANNOTATION"
:dialog-title "Converti DWG 1:1"
:toolbox-button nil
:ok-action
'(if (SD-AM-INQ-DRAWING-NO)
	(sd-call-cmds
		(progn
			(setq dwgname (SD-AM-INQ-DRAWING-NO))
			(setq scale_sheet (sinteco-string-to-number(sd-am-sheet-struct-scale (sd-am-inq-sheet (sd-am-inq-curr-sheet))))) ;convert string to number
			(AM_SAVE_SHEET_MI :SHEET (uib:get-file-manager-objects) :filename (format nil "c:/temp/~a.mi" dwgname) :overwrite )
			(SD-SYS-EXEC (format nil "~a/dxfdwg/scala1.1/dxfdwg.exe -m c:\\temp\\~a.mi" oli::*ci-percorso-pers-sinteco* dwgname))
			(am_drawing_delete :dwg :YES)
			(AM_LOAD_ANY_MI :ENABLE_WARNING :off :FILENAME (format nil "C:/Temp/~a.dwg" dwgname) )
			(am_sketch_resize :sketch "1/TOP" (/ 1 scale_sheet))
	;		(if (<= scale_sheet 1)  (am_sketch_resize :sketch "1/TOP" (/ 1 scale_sheet)) (am_sketch_resize :sketch "1/TOP" scale_sheet) )
			(AM_SAVE_SKETCH :SKETCH "1/TOP" :FILENAME (format nil "C:/Temp/~a.dwg" dwgname) :OVERWRITE)
			(system(format nil "del c:\\temp\\~a.mi" dwgname))
			(system(format nil "del c:\\temp\\~a.log" dwgname))
		:failure (sd-display-warning "Errore in conversione")
		:success (oli::undo  :NUM_STEPS 1)
