Creo 5.0 crash down without an error report
SOLVED
Highlighted
Visitor
I installed Creo 5.0 more than 10 times and I had already the same Problem. There is no mistake with the License or the Hardware (HP Envy i7 16GB Ram NVIDIA MX150).
So my Problem is: When I start Creo everythink is working, than I want to create a new profil or I want to spin the koordinatesystem. After this Creo doesn´t react, only jumps to the starting page and I can only close the window. I installed Creo 4.0, but I had the same Problem.
My CPU is working, but Nothing except a White window.
Furthermore there is no error report.
Have anybody an idea, what I can test or do different??
Thank you very much for your support.
1 ACCEPTED SOLUTION
Highlighted
Re: Creo 5.0 crash down without an error report
@Määxle192 wrote:
Yes I tried also as Administrator bevor, but also it didn´t work.
I think I have a solution. The Problem is: My Laptop has got 2 graphics. So one from Intel and one from NVIDIA. So when I deactivate the Intel in WIN10, then it works. Do you know where I can deactivate the INTEL one in BIOS, because HP don´t admit me to deactivate the INTEL in BIOS, beacause I don´t find the INTEL graphic anywhere.
Thank you very much for your support and Engagement!
Maxi
I am sorry I am not able to answer your question.
Martin Hanák
7 REPLIES 7
Highlighted
  • go to Creo_LOADPOIN\Creo 5.0.x.0\Common Files\text directory
  • open config.pro with Wordpad
  • add following option at the and of file ... graphics win32_gdi
  • start Creo a test its behaviour
Martin Hanák
Highlighted
thank you for your answer.
Unfortuately it didn´t work. I add a Picture you can see the refusal of the storage.
What else can I do?
I installed all the Hardware Driver new.
Highlighted
I can't see any picture.
Martin Hanák
Sorry for the circumstandes.
Here is the Picture: Bild support.PNGin English it means: the acces is refused.
Thank you!
Maxi
Highlighted
you do not have full access rights to this config.pro.
Suggestion: Start Wordpad as Administrator, open config.pro, modify it and save it.
Martin Hanák
Highlighted
Maxi
Highlighted
Maxi
Martin Hanák
Welcome to PTC Academic!
