I cant give dimensions on Creo 3.0 student
yayalon
1-Newbie
I installed the software today & cant give dimensions on creo 3.0 students version.
please help me, as you can see the line in the picture without the option to give dimension.
thanks a lot
are you sure you want to use Creo Layout application ? I would expect that you want to use Creo Parametric.
Idea: Look at Annotate​ tab.
MH
Martin Hanák
5 REPLIES 5
I would recommend upgrading your graphics card driver as this seems to be a graphics issue.
Let me know how it goes.
Chris
Chris thanks a lot for your reply.
I run on my system solidworks, inventor and autocad perfectly well.
I think it will be better to download an older version of creo ! what do you think?
best regards and again thanks a lot
Yonatan
MH
Martin Hanák
Yonatan,
I would try upgrading your graphics card driver first, as that's an easier process. If that doesn't help, we could look into a couple other options.
Chris
Thanks a lot for your help.
It turned out that Martin was right.
As I used Creo Parametric there wasn't any problem to give dimension.
Again thanks
Best Regards
Yonatan
