I downloaded and installed the software properly.But when i opened it, it showed a popup saying " Creo Parametric Student Edition is shutting down because it could not run the Quality agent, which is required in this edition".
So what should i do now? Please do help me in this.
You can submit an academic support request here: http://support.ptc.com/appserver/support/academic_case_logger/academic_case_logger.jsp
Worked for Creo 7.0
Thank you!!
