Translation Button - Top Right
Dale_Rosema
On (2) recent topics I used the translation button on the top right of the page.
The first time, the title and the contents were translated.
On the post below, only the title was translated not the body of the post.
6 REPLIES 6
I have noticed that the translation in the top bar only translates the title and the translation in the message post translates everything.
Dale_Rosema
(To:Dale_Rosema)
This post, the top right translation button translated everything:
Dale_Rosema
(To:Dale_Rosema)
It was the inconsistency that threw me.
AndrewK
Community Manager
(To:kdirth)
I think the line of English at the beginning of the post is causing the problem. I will take a look at the code. It has been a while, so I forget exactly what I did but I'm guessing if you use the translation on the individual message, it just sends the whole thing for translation, so it works as expected. However, if you use the translation at the top for the entire thread, it probably checks each message to make sure it needs translation and since that post begins in English it incorrectly assumes the post is already English. I'll have to experiment with it to see how it's working. Thanks for the report!
AndrewK
Community Manager
(To:Dale_Rosema)
It should translate the post. I will take a look at it.
