3-Newcomer
Creo tf_a4.frm 模板工程图 start 定位注释消失致 SVG 导出 BOM 偏移
问题反馈:Creo tf_a4.frm 模板工程图 start 定位注释消失致 SVG 导出 BOM 偏移
问题现象:使用 tf_a4.frm 最新模板制作带爆炸视图的工程图,为满足 SVG 导出需求添加「start」定位注释符号;执行【工程图保存 + 关闭 + 拭除未显示】操作后重新打开图纸,会触发系统弹窗警告,无论选择「继续」或「审阅」,添加的「start」定位注释均直接消失;最终导致该工程图导出的 SVG 文件中,右侧 BOM 清单位置出现偏移,无法正常对齐
Emeritus
Hi @GD_14314423,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
