CREO can no longer be installed
ptc-4523676
I uninstalled my student copy of CREO, and then later attempted to reinstall it. I can no longer generate a license for CREO though, when I enter my SOM number it reads 'processing' and then 'failed'. I'm not entirely sure what I can do about this?
Are you trying to generate this license using the PIM app or using the online form?
Hi Adam,
Thanks for your reply, I was using the licensing setup program, I've now tried the online form. The online form also fails, it tells me that I have entered an incorrect product code. The product code I'm using is copy/pasted from my registration about two months ago? Is there anyway I could generate a new product code?
Edit: I have installed CREO, however the problem still lies in the licensing, my old license .bat file is no longer accepeted by CREO for some reason, at startup a window pops up regarding the license file, when I close the window CREO then closes. I still can not generate a new license file.
I am using CREO 1.0 Parametric.
Meetal,
Unfortunately I cannot help you with this. You'll have to open a support request with the licensing team at: http://www.ptc.com/company/community/schools/support.htm.
They will be able to find out what the problem is.
Adam
