Creo 1.0 License problem
ptc-6756880
Hello
I have a Problem with Creo 1.0.
I installed it with a Licence.dat what worked perfect.
But if i try to start it i get this error.
My system is Win7 enterprise and it runs in the Bootcamp of my MacBook Pro.
I hope you can help me.
Greetings Christoph
3 REPLIES 3
Hello Christoph,
As I can see the license file was generated for a different Host ID then the one used now. This problem may be solved by changing the state of your Wireless and restart the program.
If changing the state of your wireless network card won’t help, check if the Host ID matches to the one that your license is locked to: 00-13-02-38-91-42.
You can check the Host ID of your MacBook by running this application: http://apps.ptc.com/schools/Get_HostID.zip
If the Host ID of your laptop is not the one that the license was locked to you will need a new license file for your laptop.
Alex
How to get and new license if the host id is not the same or locked. ?
Any Creo license file is locked to an Host ID. If you licensed Creeo using Wifi, you might need to turn Wifi on in order to enable the wireless network card that your license is locked to.
If this doesn't work, please make a request for Academic Support and you will get the help you need.
Academic Support Request | PTC Academic Program | PTC
Alex
