My son has asked for us to download the Student Version of Creo 3.0 onto his computer.
Does anyone know if it will run and is supported on Windows 10 ?
The build code of Creo 3.0 on Windows 10 is M060 and higher now.
Abdul
Welcome to PTC Community Mark - I am moving this to the Academic area to get it in front of the most relevant audience.
Best,
Toby
Windows 10 is supported on Creo 3.0 M060 and later. |
The commercial version is updated every few months but I am not sure how often the academic version is updated.
With that said, you also need to check the graphics card in your son's computer.
While older builds of Creo3 MAY work on Windows 10, PTC would need to verify that the academic version is at build M050 or higher.
Abdul
