my name is Elias from Germany. I installed Creo 7 correctly and I’m happy with it. The next days, I would like to do my master’s degree with Creo 7 Generative-Design. Unfortunately, it's not in the student license included. Is there any option to use the latest version of Simulate and Generative-Design for free or as a low budget student license or something like that? Did I do something wrong with installation? Thanks in advance for help!
Regards
Elias
Regards
Elias
Student license does not contain codes needed for running Simulate and Generative-Design.
Ask CAD admin at your university. I hope he will tell you whether Academic license available in university lab contain Simulate and Generative-Design codes. Maybe he will also enable you to "borrow" Academic license.
thank you for your Help! I got it work, that I ‘can use an academic license for my project. I'm busy with getting the full version of "Generative-Design" which includes the modal based optimization.
Regards Elias
Hello again,
now I have access to an academic license of Creo Parametric for my project. The license is a "university plus license". With this I have access to a stripped-down version of "Generative Design". Does the "university plus license" include a full version of "Generative Design"? With full version modal-analysis-based and thermal-based topology optimizations should be possible then. Is the "send to cloud" option activated in my version?
Thanks for your help!!
Regards Elias
@EO_9850652 wrote:
Hello again,
Regards Elias
maybe @Alex_Cazacu can provide more information.
Hello Elias,
I'm currently working on my master thesis as well and will do some analysis with Generative Design. Can you give me some tips on how to install the student version? Have you already solved the problem that you can use Generative Design to the full potential?
Thanks a lot for your tips!
Greetings from Germany as well
Recep
I use the academic license. As far as I know, the freely accessible student license does not include "Generative Design". The academic version offers the GTO plugin which is simplified the slimmed down version of the GDX.
Regards
Elias
FYI:
https://ptc-solutions.de/produkte/creo-parametric/erweiterungen/cad-konstruktion/generatives-design
