The install had no issues, when I try to run it, I get the following error.
and when I select Yes, then I get the next error see below and then Creo closes.
How do I fix this? Do I need to delete everything and start over?
Try this tip - "Creo Agent did not initialize correctly": https://community.ptc.com/t5/PTC-Education-Forum/Creo-Agent-did-not-initialize-correctly-Please-contact-technical/m-p/732275#M12112
