The installer of any University approved version of PTC CREO (7.0.8.0 and 9.0.0.0) is not running with no error message given. The process simply terminates after a few seconds before a window is opened.
System Specs:
Windows 11 23H2
AMD Ryzen 3900X
Nvidia RTX 2080 Super
64 GB Ram
200 GB free SSD storage on C:
Similar discussions:
The only thing that I was able to do now is have a second boot drive with a second windows installation. Far from ideal.
The usual run as administrator and kill all unnecessary processes did not work. I also tried to install in protected mode but that failed, not because of the setup.exe not running but because of some required component being not available.
1.]
What is full absolute path to setup.exe you are starting?
2.]
What language version of Windows is installed on your computer?
As recommended in a different thread I moved the installation files to C:\install
My computer is running on German Windows. Though I don't think that affected the installation as I was able to install CREO 5 and 7 previously during my Bachelors.
I did manage to create a memory dump file from the setup.exe before it closed if that would be of help for bug fix purposes.
probably my last tip ...
No change. I still get the busy cursor for a second or two with the program showing up in task manager for that time only.
2 tips:
