Apr 16, 2024 4:40 PM UTC
Can't install Creo 9.0 for windows11
I want to install Creo 9.0. I succeeded in unzipping file "MED-100WIN-CD-460_9-0-0-0_Win64". But I couldn't open setup.exe and install_licenseserver.exe in my computer. When I searched control panel and task manager, I couldn't find any app in operations.
When I forced shutdown, I found "unnamed" file is running. Maybe this file is setup.exe which I tried to open.
Here is my laptop information.
CPU 13th Gen Intel(R) Core(TM) i7-13700H 2.40 GHz
RAM 32.0 GB
OS window11 home
Thank you for your support.
8-Gravel
Oct 30, 2024 5:01 PM UTC
I am having the exact same issue and have found no answers. When I attempt to run the "setup.exe" file, a popup appears asking if I will allow the app to make changes. Then, nothing. I checked the windows event logs and found an error, as posted in the picture below. Still no answer. I have tried re-downloading the zip file directly from the website multiple times. I genuinely have no idea what to do.
Oct 31, 2024 2:33 PM UTC
just to be sure, try removing the space from the directory name. Then run setup.exe again
  • for example: change C:\Creo Setup to C:\Creo_Setup
8-Gravel
Oct 31, 2024 2:36 PM UTC
I sincerely appreciate your help, and I actually JUST tried this. Still no dice, even after deleting all files, redownloading the zip file, extracting into the newly named PTC_install file, right click run as admin, nothing. I get the popup asking if I would like to let the ap make changes, I say yes, I get the little blue circle cursor for a few seconds and poof.
Oct 31, 2024 8:30 AM UTC
