Hi, I just downloaded Creo 2.0 from ptc as a student edition download, including the simluate. But, when I run this program, and try to open a part/model, it throws this license error: "unable to get required creo simulate license. Please contact customer support". Do I need separate license for simulate, because the parametric seems to be working fine.
A. Gill
Sorry Gill but the Student edition of Creo does not include licensing for Creo Simulate. If you want to use Simulate you'll need the Academic Edition which can be purchased from http://store.ptc.com.
Adam
Adam
hi , is there a way to open creo para saved files without creo simulate.
