Creo for windows 8.1?
rrussell
Hello all,
I was wondering if anyone knows how to get creo on a computer running on Wndows 8.1? And if I need to update creo when will that update be availible? Because i just got a shiny new HP Pavillion for the holidays and I've been using creo alot for this current season but on a seperate computer that was running on windows 7. I don't believe the windows 8 version runs on windows 8.1. So if anyone knows when the update will be availible that would be glorious.
Thank you!
-Bo
AdamHaas
(To:rrussell)
Bo,
If you are using Creo 2.0 (build code M070), it is certified to work with Windows 8.0. I have not heard of any issues with 8.1 so I would assume it is working with that also (but not certified).
Adam
4 REPLIES 4
AdamHaas
(To:rrussell)
Bo,
Adam
bjolin
(To:AdamHaas)
I have an HP Pavilion as well. It will not run it.
sm
(To:rrussell)
Hi, PTC is offering Creo 2.0 M100 through the Academic download portal, so just grab the latest build if that's not what you are working with. If it is, I would recommend dropping a post in the Academic Support community with the specifics of the issue(s) you are encountering to see if someone can help you out. I have had Creo 2.0 running on Windows 8.0 and 8.1 for a long time on Dell hardware. I am not aware of any hardware specific issues with HP.
