Guten Tag,
nach der Registrierung auf der Seite "http://www.ptc-de.com/de/academic-program/academic-products/free-software/creo-college-download" gelangt man zu einer Seite ("http://.../thank-you"), auf der die Installationsanweisungen für unterschiedliche Versionen verlinked sind.
Hier erhält man aber für Creo 3 einen falschen Link zur Installationsanleitung der Schools-Edition und nicht zur Student-Edition. Eine Installation der Student-Edition ist ohne den erforderlichen Produktcode aber nicht möglich. Bitte möglichst bald korrigieren...
FYI ...
If you can install Creo 5.0 you will receive license file. Later you can use this file during Creo 3.0 installation.
Creo 5.0 product codes
K-12       students can use Product code BE500806EDSTUDENTEDK12
University students can use Product code BK500806ED0790-Y3M9-4RW5
See also attached PDF documents.
Wow, what a solution..![]()
Instead of downloading ~4Gig for Creo3 now in addition ~4Gig for Creo 5.
Hm, after creation of license file in Creo5-setup, it should be possible to cancel setup without installing the complete creo5.
But the feature name in different versions of creo student-editions are not the same. So I think creo3 will not run with a creo5 license.
No, that's no solution.
But meanwhile I found the correct link and the correct productcode for C3 in the www.
There are so many misstakes/differences between the german ptc/de and the english ptc/en hompages.
 Maybe PTC will do its homework somtime.
Thank for the "try"
FYI ... creo3 will run with a creo5 license.
Oh, that's new.
I tried to run Creo2 with a Creo3 license and that did not work.
So that has been changed by PTC - good to know, thank you.
