Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
Hello, We are an Oklahoma team from Francis Tuttle. Francis Tuttle has two teams this year, and we are both having the following problem: We are using ProE 4.0 build M092. FlowEFD is installed correctly. We have recieved the following error: "-Rebuild Error There is no fluid volume in the project. Please check geometry or boundary conditions." We have multiple models and have tried multiple times to run simulations following the video each time. Thank you so much in advance for your help.
Hi arielle, I just uploaded a solution video for this particular issue on the RWDC Getting Started page. pelase review the video and update your model following the defined steps. This should address the issue. In addition, make sure your model is regenerated and saved. Thanks, Mark
