How To Remove Creo Trial Win10
RM_2351450
I have a trial edition of Creo supplied by Tarek Makhlouf and I no longer have need for the trial software.
I need to uninstall the software. I need instruction to remove all bits and pieces of the software from my computer.
Please supply the needed information.
Hi @RM_2351450,
You can uninstall Creo Parametric 9.0.0.0 from control panel
Right click on above application within control panel and select uninstall. Once done make sure you select the radio button as below
After performing the above steps you also need to uninstall PTC Creo Player from control panel in similar manner
I hope this should help
Vipul
1 REPLY 1
Hi @RM_2351450,
Vipul
