Hi @RM_2351450,
You can uninstall Creo Parametric 9.0.0.0 from control panel
Right click on above application within control panel and select uninstall. Once done make sure you select the radio button as below
After performing the above steps you also need to uninstall PTC Creo Player from control panel in similar manner
I hope this should help
Vipul
Hi @RM_2351450,
Vipul
