I have downloaded creo 3.0, but every time i hit run on "setup.exe" it asks permission to make changes to the computer, then i hit "yes", and then nothing happens. How can i fix that?
  • February 7, 2017
  • 4 replies
  • 3672 views
Please help
    Did you try to right mouse click on the setup.exe and choose "Run as Administrator"?
    rtruitt1-VisitorAuthor
    I have Windows 10 Microsoft Edge, when I right click, the options that come up are "open", "open inside", or "open outside". Tried all 3 and none worked. There is no option to "run" or "run as administrator".
    I've also turned off all anti-virus systems as well with no success
    Toby Metcalf‌, can you move this to academic support.
    You may have a bad download.
    I've heard of issues with  download manager, used to it only worked well with firefox. (I can't verify if that has been fixed).
    Dear Ryan,
    This is because of Virus problem in your PC. Please clear all the virus and then try to install it. I suffered from same problem.
    If it not works, Contact me I will help you..
    Thank You
    Saurabh Kulkarni
    So now I have re-downloaded it with Chrome onto the same laptop and it still wont open when I hit "open" and then "yes, make changes to the computer" on the "setup.exe" file. I also rescanned my computer and it could not find any viruses. I do not know what else I can do, any other suggestions?
    OK, you downloaded zip file.
    In what folder is it located ?
    What is its name ?
    Did you unzip it ? In what folder ?
    MH
    Moving to academic support
