We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
I just downloaded creo parametric 3.0 for students, and it runs super slow. Any suggestions or help?
Good day and welcome Marah -
I am moving this to the Academic Community to give your question the best exposure.
Best,
Toby
usually it is graphics problem. Add following option at the end of config.pro file and test Creo behavior.
graphics win32_gdi
MH
What are your computer specs?
Intel Core i7-6500U CPU @ 2.50 Ghz
12.0 GB RAM
64-bit Operating System, x64-based processor
It's a Lenovo ideapad
What's the Graphics chip?
The graphics processor being used is Intel HD Graphics 520, on my computer. The processor speed is 2592 MHz.
try following config.pro options
enable_opengl_fbo no
enable_opengl_vbo no
enable_opengl_shader no
graphics win32_gdi
MH
Sorry-I've never done this before...Can you give me a little more direction as to where I can do this on my computer? Is it within the program?
Thank you so much
Create a text file in your start-in directory of Creo named config.pro and put the 2 lines Martin shows in that file and save it. Then restart Creo.
Look at the properties for the shortcut you use to launch Creo to see what folder is your start-in directory.
in my Creo 2.0 installation there is C:\PTC\Creo2_M070\Creo 2.0\Common Files\M070\text\config.pro file. In Creo 3.0 the path to config.pro is slightly different. Edit this file using Wordpad.
MH
