Here's a possible solution: "Something is blocking the connection between PC and the licensing server. Please make sure that you temporary disable the antivirus and firewall during the licensing process".
thank you for replying
I tried disabling the antivirus and firewall, I got the same issue ( using 3 different laptops ), any other recommended solution ?
Best regards
