Issue with creo.8 educational
MR_4296897
2-Explorer
Hi
when I entered the license identification as BK800908EDSTUDENTEDUNI , installation is freeze at "processing " , I tried using different laptops, unfortunately I got the same Issue
Here's a possible solution: "Something is blocking the connection between PC and the licensing server. Please make sure that you temporary disable the antivirus and firewall during the licensing process".
thank you for replying
I tried disabling the antivirus and firewall, I got the same issue ( using 3 different laptops ), any other recommended solution ?
Best regards
Try it at another time.
P.S. @Alex_Cazacu
