I had some problems installing the program the first time so i reinstalled it but now im getting this error?
I'm assuming that you are licensing Creo 4.0 on your computer, as the code inserted is for Creo 4.0.
Please use the code: BE410708EDSTUDENTEDK12
The issue is that the code you are using works only once per user per year, so it was used first time when the installation didn't work.
Alex
