License error during Installation of Creo 5-Student version-Please help
  • October 30, 2018
  • 5360 views
This error message prevents the installationThis error message prevents the installation
JoelJ941-VisitorAuthor
Hi Martin, I have not received the license file via email.  The contents of my ip.txt file are as follows:
Windows IP Configuration
Host Name . . . . . . . . . . . . : LAPTOP-1SNOPV5P
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 6A-14-01-B3-F1-B3
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 6A-14-01-B3-F9-B3
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : TAP Adapter V9 for Private Tunnel
Physical Address. . . . . . . . . : 00-FF-3C-24-C6-30
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller #2
Physical Address. . . . . . . . . : EC-8E-B5-A7-27-D4
Link-local IPv6 Address . . . . . : fe80::c928:c645:833e:e6%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.100.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, October 29, 2018 2:41:04 PM
Lease Expires . . . . . . . . . . : Sunday, November 4, 2018 11:05:13 AM
Default Gateway . . . . . . . . . : 192.168.100.1
DHCP Server . . . . . . . . . . . : 192.168.100.1
DHCPv6 IAID . . . . . . . . . . . : 65834677
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-18-3C-2B-EC-8E-B5-A7-27-D4
DNS Servers . . . . . . . . . . . : 192.168.100.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter WiFi:
Description . . . . . . . . . . . : Broadcom BCM43142 802.11 bgn Wi-Fi M.2 Adapter
Physical Address. . . . . . . . . : 68-14-01-B3-F1-B3
Ethernet adapter Bluetooth Network Connection 2:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #2
Physical Address. . . . . . . . . : 68-14-01-B3-F1-B4
Hi Martin, I am not so familiar with those settings and could not find them(the network adapters). I was also not able to find that  licensing directory file path. Shall we connect using teamviewer ?Would be more helpful.
