Hi I'm having an issue with my license authorization can you help me out with that?
what Creo version?
@ND_10591967 wrote:
11
did you read following documents?
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
@ND_10591967 wrote:
Yes, but I’ll try again just to make sure.
if you are going to repeat the installation, then make a detailed record of the installation steps (in the form of pictures) and publish it in case of installation failure.
Note: Your original picture probably informs that you skipped licensing during initial installation.
