I tried to install Creo 7.0.8.0 by following the "PTC Creo 7.0 - Student Edition - Quick Installation Guide" (I deactivated real time protection, cloud based protection, manipulation prevention, controlled folder access, smart app control, the firewall, made sure there were no old licenses and ran it as admin) but the installer won´t even start. I am running win11 22H2 and there was 7.0.2.0 once installed but it´s now uninstalled. I tried searching for similar entries in the forum but the informaton I´ve found seems to be conflicting. There are entries suggesting that that´s what happens when the installer doesn´t support win11 but support articles state that win11 is supported as of 7.0.7.0.
Hi SD,
Try this Creo 7.0.9.0. This is the latest release and it should work.
Please note that the one that I've shared a link to is just the install from web.
Let me know, please if this solves your issue!
~Alex
I hope that you know that path to setup.exe file must not contain national characters.
Unzip installation package and move it into C:\PTC_install directory (for example). Then start C:\PTC_install\setup.exe
I tried it and it didn´t behave diffferently. My original path also didn´t include any national caracters. I´ve included a log I found of one previous try.
there is no error message in log file. The only suspicious "thing" is :
Vorhandene SessionInfo-Datei C:\Users\sebas\AppData\Roaming\pim\sessioninfo.xml gefunden.
Suggestion: remove C:\Users\sebas\AppData\Roaming\pim\sessioninfo.xml file and run setup.exe again.
Tip: Maybe installer is corrupted.
Suggestion: Download it again and unzip it using 7-zip.
I tried it with a new download after removing the pim folder, still didn´t work. I even tried launching it in compatability mode.
Hi SD,
~Alex
